I touched on this question my first post but it kind of got lost in the other responses so I thought I would ask it again in it’s own topic…
Pretty basic question: How can I get a clear glossy finish over carbon fiber without using a mold?
I’ve seen people suggest rolling on extra layers of resin, applying a spray-on gel coat like duratec. However I’ve recently seen a suggestion of applying a layer of regular fiberglass cloth on top of the carbon and then sanding it down smooth prior to applying an automotive style clear coat. I know fiberglass becomes transparent with the application of resin, but does it get THAT clear that you could still see the carbon cloth perfectly through it?
What would you guys suggest as the best approach for an amateur with no specialized tools (gel coat spray guns, wire rolers, or anything else really).
-Matt
