I think I already know the answer to this one but here it goes.
I did everything exactly as I always do- only difference is the temperature is much colder. I cleaned the mold, hit it with some semi permanent mold release, wait around an hour, sprayed my clear gel coat into the mold (10 drops of MEKP per oz.) and I let it sit until the next day. Came back, made sure the gel coat wasn’t tacky, laid my carbon in the mold, vacuumed with infusion and let it set under a heat lamp. It took forever to cure and when I pulled it from the mold just now, a huge chunk of the clear gel coat stuck in the mold.
It doesn’t seem to be a problem with the semi permanent mold release that Evan sells because you can scratch the gel coat out with your finger and the mold looks like it’s ready to go again.
Is the problem with the colder temps? If so, how should I be mixing my clear gel coat?
