Hi guys.
This is more brain picking than anything else.
I use VTF261 as a surface (out of autoclave). For clear coating, I normally hit it with one coat, sand, then repeat as many times as necessary until the part is flat. This is getting tedious and so time consuming every time I make a part it makes less and less sense to clear it. However, it has to be cleared for UV, gloss, and most of all, depth.
Normally, parts come out quite well out of the mould. Very smooth and to the naked eye, pinhole free:
However, when clear coated, it’s like a rash:
Tried cleaning with both mould cleaner, acetone and thinners in case it’s a release agent issue. Nothing.
Tried sanding it quite a bit, no difference.
I believe it’s the carbon that’s drinking the lacquer through the pinholes.
Basically, does anyone have a quick and easy way of clearing OOA prepreg that doesn’t involve 5 coats of clear and days of sanding?
