So lately I’ve been trying to stay away from gel coats and I’ve noticed when I wet sand and wipe with a light solvent for clear coat, it looks good. But then when I clear coat it, I get tiny hairs. Like some hairs are absorbing the clear coat. I then have to wet sand and re clear which is a pain since my clear is $300 a gallon…
So what am I doing wrong? I infuse it with infusion resin from fiberglasssupplies.com. Should I reduce the resin to help saturate the fabric more? Or is this just how it is when using polyester / vinyl ester resins. I don’t want to use epoxies unless somebody can direct me an infusion epoxy that has a high heat distortion temp and a low cure temp.
The reason I’m trying to stay away form a clear gel coat on certain parts is because sometimes it cracks when demolding, and its a real PITA to apply and clean. That and time consuming. We’re a fast pace shop we don’t have time haha.
Thanks,
John
