Is a pump like this acceptable for smaller scale infusions and vacuum bagging projects?
http://www.harborfreight.com/25-cfm-vacuum-pump-98076.html
Is there a different type or brand of pump that you guys would suggest?
Thanks!
Thanks!
Any one have any suggestions on a cost effective option for a vacuum pump?
That pump should do it.
Keep in mind that it does smoke somewhat. Also order the hose barb to allow connection of a hose, as these units usually have an obscure thread.
It will draw a deep vacuum. Make sure you have no leaks, and for visual parts, MTI hose is recommended.
