Can you guys tell me what is causing these problems you see in these pictures?
Hood was made in two stages. First 2 layers CF and then vacuum bagged. Then honeycombs and 2 layers CF and again vacuum bagged. Im using SP 115 epoxy resin. I had a minor leak in bag, but since I’m not using infusion that shouldn’t be a problem, should it?
Thanks for your help!
I’m going to try and save the “ruined” hood with CF overlay since I really don’t want to do a painted version. For my next part I will try the vacuum infusion method as baznos suggested. Let’s see what happens
