I’m looking to make charge pipes for a turbo car.
There are 2 pipes, a hot side and cold side. Cold side will be less than 100f; hot side can be north of 300 but probably never over 450* [I need to verify].
These pipes will constantly be in between 10 and 20 PSI.
[ul]
[li]So I need sources for some real high temp epoxy? I have had poor luck finding one[/li][li]Is it worth even making the hot side?[/li][li]What should I use for connectors, I’m thinking silicon adapter style “bead roll” at the end? How would you accomplish this in CF? Other suggestions?[/li][li]I’m thinking I will make the mold by heating up PVC pipe and bending it to the exact shape I need; then maybe cutting it down the middle and laying CF in either side, trimming it off with a razor when it sets, then binding the two sides together with more resin. Then either wrapping around it with another layer and off-setting the seam? or maybe getting one of those pipe wrap “Chinese finger toy” style deals to finish them?[/li][li]How many layers of CF do I need to hold pressure like that?[/li][li]Anyone ever experiment with using some fore of automotive ceramic temp spray to keep heat out of the CF? like for headers[/li][li]When molding in PVC how do I need to prepare it? Keep in mind for the previous resin request that PVC deforms at 140*[/li][/ul]I hope that wasn’t to dense ha, lots of questions.
First post!
I have used fiberglass a good bit, I have never worked in CF…
