I am working on a few new mold designs and have been looking into casting the detailed areas. The reason for casting is there will be multiple mold design attempts with various resin and air flow channel testing before moving on to the final mold design.
I am looking for a material which can be poured, will dry relatively hard, and will take a number of mold cycles. These will not be production molds, but rather for testing. Material used for the part is epoxy resin with 60-80 psi internal bladders, post cure temps under 120 F. Similar to the mold design below.
