Hi guys
I’ve got a little quandary on my hands and I thought I’d bring it to the brains trust on here
I want to cnc machine a female mold from epoxy board. I will be making RC gliders from it , which will be bagged in mold fm glass and carbon etc and post cured at around 50’C.
The problem I have is it is 2m Span , and from nose to TE ( trailing edge of wing) is 540mm. (similar to pic Attached of smaller brother)
The wing part is thin ,but my problem arises with the centre which is at a different angle to the wing.
So if you hold the TE in a flat bench the nose of the aircraft is up in the air by 40mm or so.
Thus I need a tooling board around 80mm to 100mm thick. estimated … I will know exactly what is needed once the CAD is 100% finished.
I’ve played around with other tooling board in the past , and used necuron board on a set of female molds. I have spoken to pleanty of companies but it seem what I need no one makes.
SO… I’m going down the road of casting my own ??? Has anyone done this ?? I’ve spoken to a few companies who said aluminum fill epoxy could be good for what I need.
I need to to be polishable , I use epoxy molds with durance high gloss at the moment.
I know I won’t get that type of Finnish with casting epoxy but if I can get close and then polish the part once out it might be an option.
I would use corian or freestyle bench top solid surface , but doesn’t come thick enough.
I have a set of corian molds which are nice , and I can polish the part well.
I don’t really want to go down the MDF plug and build molds from that… To much time on this bigger project.
I rather machine something , and polish it and have one set of female molds.
I wish I could afford an aluminum set of molds ha ha
So any suggestions , or some positive and negatives would be of great help. I’m sure with the amount of knowledge on here we can come up with a direction to take.
Thank guys look forward to what you come up with
Tim
These are gizmo 36 rc glider
Shows you size. These are 900mm wing Span.
Th
