Because, for our Technique of Forced Infusion , We need PVA Bags (6’’) , And the PVA mold very well the C.F. , Only thing with PVA Bags , they crack very easy ! I need to be very careful … like a women
If someone know or work with CARBON ACRYL resin (Methyl Methacrylate) just let me know , Im very curious about it !
For PVA Bags ( Poly-Vinyl Alcohol Film), there alot in Canada and United States, look on Ortoped.ca
Spec/Info: PVA Bag
Supplier:
SPT Technology, Inc.
Features & Benefits:
• Double sealed, poly vinyl alcohol separator in various
lamination techniques
• Tapered design acommodates ease of application and use of
lamination materials
• When using the closed end model, installing a distal cap is unecessary
Specifications:
• Models: PVA Bag (open end)
Closed End PVA Bag
• Material: Poly-Vinyl Alcohol
• Thickness: 3 mil (.08mm)
• Length: PVA Bag= 1,020mm (40") and 1,300mm (51")
Closed End PVA Bag= 1,020mm (40")
• Proximal diameter: PVA Bag= 51cm (20")*
Closed End PVA Bag= 100mm (4"), 150mm (6"),
200mm (8"), 250mm (10"),
300mm (12"), 350mm (14")
and 400mm (16")
(* Other diameters available; see chart for more information)
• Distal diameters: See chart for more information
• Use over a dry cast or insert
Indications:
• Prosthetic and orthotic lamination applications
Contraindications:
• Some residual transtibial shapes
Call Points:
• Prosthetist
• Prosthetic technician
• Orthotist
• Orthotic technician
Warranty:
• Against manufacturers defects
SPT-PVA 4 Poly-vinyl alcohol lamination separators 1020mm (40") 510mm (20") 100mm (4") 20 bags / pack
SPT-PVA 6 Poly-vinyl alcohol lamination separators 1020mm (40") 510mm (20") 150mm (6") 20 bags / pack
SPT-PVA 8 Poly-vinyl alcohol lamination separators 1020mm (40") 510mm (20") 200mm (8") 20 bags / pack
SPT-PVA 10 Poly-vinyl alcohol lamination separators 1020mm (40") 510mm (20") 250mm (10") 20 bags / pack
SPT-PVA 12 Poly-vinyl alcohol lamination separators 1020mm (40") 510mm (20") 310mm (12") 20 bags / pack
SPT-PVA 14 Poly-vinyl alcohol lamination separators 1020mm (40") 510mm (20") 360mm (14") 10 bags / pack
SPT-PVA 16 Poly-vinyl alcohol lamination separators 1020mm (40") 510mm (20") 410mm (16") 10 bags / pack
SPT-PVA 18 Poly-vinyl alcohol lamination separators 1020mm (40") 510mm (20") 460mm (18") 10 bags / pack
SPT-PVA 20 Poly-vinyl alcohol lamination separators 1020mm (40") 510mm (20") 510mm (20") 10 bags / pack
SPT-PVA S-6 Poly-vinyl alcohol lamination separators 1300mm (51") 220mm (85∕8") 50mm (2") 5 rolls / pack
SPT-PVA S-7 Poly-vinyl alcohol lamination separators 1300mm (51") 250mm (10¼") 50mm (2") 5 rolls / pack
SPT-PVA S-8 Poly-vinyl alcohol lamination separators 1300mm (51") 190mm (7½") 50mm (2") 5 rolls / pack
SPT-PVA S-20 Poly-vinyl alcohol lamination separators 1300mm (51") 510mm (20") 200mm (8") 5 rolls / pack
SPT-PVA S-25 Poly-vinyl alcohol lamination separators 1300mm (51") 510mm (25") 230mm (9") 5 rolls / pack
Closed End PVA Bags
SPT-PVA4 CE-0 Closed end PVA lamination separators 1020mm (40") 100mm (4") 63.5mm (2½") 5 bags / pack
SPT-PVA4 CE-00 Closed end PVA lamination separators 1020mm (40") 100mm (4") 50.8mm (2") 5 bags / pack
SPT-PVA4 CE-000 Closed end PVA lamination separators 1020mm (40") 100mm (4") 44.5mm (1¾") 5 bags / pack
SPT-PVA6 CE-1 Closed end PVA lamination separators 1020mm (40") 150mm (6") 76mm (3") 5 bags / pack
SPT-PVA6 CE-2 Closed end PVA lamination separators 1020mm (40") 150mm (6") 89mm (3½") 5 bags / pack
SPT-PVA6 CE-3 Closed end PVA lamination separators 1020mm (40") 150mm (6") 102mm (4") 5 bags / pack
SPT-PVA6 CE-4 Closed end PVA lamination separators 1020mm (40") 150mm (6") 114mm (4½") 5 bags / pack
SPT-PVA6 CE-5 Closed end PVA lamination separators 1020mm (40") 150mm (6") 127mm (5") 5 bags / pack
SPT-PVA8 CE-2 Closed end PVA lamination separators 1020mm (40") 200mm (8") 89mm (3½") 5 bags / pack
SPT-PVA8 CE-3 Closed end PVA lamination separators 1020mm (40") 200mm (8") 102mm (4") 5 bags / pack
SPT-PVA8 CE-4 Closed end PVA lamination separators 1020mm (40") 200mm (8") 114mm (4½") 5 bags / pack
SPT-PVA8 CE-5 Closed end PVA lamination separators 1020mm (40") 200mm (8") 127mm (5") 5 bags / pack
SPT-PVA10 CE-2 Closed end PVA lamination separators 1020mm (40") 250mm (10") 89mm (3½") 5 bags / pack
SPT-PVA10 CE-3 Closed end PVA lamination separators 1020mm (40") 250mm (10") 102mm (4") 5 bags / pack
SPT-PVA10 CE-4 Closed end PVA lamination separators 1020mm (40") 250mm (10") 114mm (4½") 5 bags / pack
SPT-PVA10 CE-5 Closed end PVA lamination separators 1020mm (40") 250mm (10") 127mm (5") 5 bags / pack
SPT-PVA10 CE-6 Closed end PVA lamination separators 1020mm (40") 250mm (10") 140mm (5½") 5 bags / pack
SPT-PVA10 CE-7 Closed end PVA lamination separators 1020mm (40") 250mm (10") 158mm (6¼") 5 bags / pack
SPT-PVA12 CE-2 Closed end PVA lamination separators 1020mm (40") 300mm (12") 89mm (3½") 5 bags / pack
SPT-PVA12 CE-3 Closed end PVA lamination separators 1020mm (40") 300mm (12") 102mm (4") 5 bags / pack
SPT-PVA12 CE-4 Closed end PVA lamination separators 1020mm (40") 300mm (12") 114mm (4½") 5 bags / pack
SPT-PVA12 CE-5 Closed end PVA lamination separators 1020mm (40") 300mm (12") 127mm (5") 5 bags / pack
SPT-PVA12 CE-6 Closed end PVA lamination separators 1020mm (40") 300mm (12") 140mm (5½") 5 bags / pack
SPT-PVA12 CE-7 Closed end PVA lamination separators 1020mm (40") 300mm (12") 158mm (6¼") 5 bags / pack
SPT-PVA14 CE-2 Closed end PVA lamination separators 1020mm (40") 350mm (14") 89mm (3½") 5 bags / pack
SPT-PVA14 CE-3 Closed end PVA lamination separators 1020mm (40") 350mm (14") 102mm (4") 5 bags / pack
SPT-PVA14 CE-4 Closed end PVA lamination separators 1020mm (40") 350mm (14") 114mm (4½") 5 bags / pack
SPT-PVA14 CE-5 Closed end PVA lamination separators 1020mm (40") 350mm (14") 127mm (5") 5 bags / pack
SPT-PVA14 CE-6 Closed end PVA lamination separators 1020mm (40") 350mm (14") 140mm (5½") 5 bags / pack
SPT-PVA14 CE-7 Closed end PVA lamination separators 1020mm (40") 350mm (14") 158mm (6¼") 5 bags / pack
SPT-PVA16 CE-3 Closed end PVA lamination separators 1020mm (40") 400mm (16") 102mm (4") 5 bags / pack
SPT-PVA16 CE-4 Closed end PVA lamination separators 1020mm (40") 400mm (16") 114mm (4½") 5 bags / pack
SPT-PVA16 CE-5 Closed end PVA lamination separators 1020mm (40") 400mm (16") 127mm (5") 5 bags / pack
SPT-PVA16 CE-6 Closed end PVA lamination separators 1020mm (40") 400mm (16") 140mm (5½") 5 bags / pack
SPT-PVA16 CE-7 Closed end PVA lamination separators 1020mm (40") 400mm (16") 158mm (6¼") 5 bags / pack
