What is the ideal mix of weave , fiber density, for acheiving the strongest component. I am looking to use vacuum bagging to make my part (motorcycle sub-frame) and leaning toward 3K twill. I realize that 6K would allow quicker build-up but would how much more structural integrity is gained by using it? (I imagine that 2 plys of 3K would be stronger then 1 ply of 6K, is my assumption correct?)
Should I be using HS, Plain, or twill weave? How much/ how does the weave effect the strength? For a given # of layers of 3K vs 6K what is the strength benefit?
I am really concerned about strength of the component as I said before, because it has to be able to bear the load of my ass and any road bumps etc.
Also, for mounting the component it has to be bolted on the bike. Should I lay the fiber in a way to allow a hole for the bolt to pass through, or should I just use a high speed drill to carefully drill through the cured component?
Thanks in advance.
) you know what I mean?
