Yep, similar to above… i made many kiteboards years ago… i did clear carbon finish boards among others aswell…
The problem is, core crush under the foot area… divinicell h80kg/m3 (or similar) does not have anywhere near enough compressive strength properties in this area. Youd have to go upto something much higher density such as 250kg/m3 foam under the foot bindings area of the board, the rest you can use much lower density foam or other material- i know, because i had a few break before i knew this… Problem is, its very expensive and you only need a small amount so buying 1 full 2400x1200mm sheet will cost more than the entire project including labour… you might consider a foaming epoxy instead and pour you own, or perhaps a high density end grain balsa???
UD carbon i used in some boards, others not. It depends on the stiffness you trying to acheive. Youd have to ask the guy if he likes a stiff board or not. If he likes it stiff, use the UD carbon in the layup. If he likes flex, just use triax glass and overlay a light carbon woven cloth - which is only there to get the carbon look. Also, you have to use a resin with a high Tg or HDT as the carbon look gets extremly hot in the sun. It can generate enough heat to soften the resin and then it can warp the board… So choose your resin carefully if going for the carbon look, i used to use a vinyl ester for mine with a very high Tg…
As to the method, i used to vac bag them on a peice of 3mm aluminium sheet. I had a frame under it, and threaded rods so i could adjust the rocker in the aluminium. This limits you to a flat bottom with single rocker curve tho, no channels as the previous poster mentioned. If i was to do it again today, i would infuse them rather than vac bag it, and use a complete envelope bag if you need channels in the bottom. Shape the foam core accordingly. I used sheet PVC or ABS plastic as inserts for the foot bindings to thread into- resin will stick well to this plastic if you rough it up and quickly pass a gas flame over it to activate the surface even more.
To finish the board, after the bagging is cured, trim up the edges and peel off the peel ply, then i used to spray a low viscosity polyester resin directly onto it with a spraygun. It was a surfboard finishing resin to which i thinned with styrene monomer and added additional wax in styrene - i had to experment a bit with this in order to get slick results. After spraying, the finish was excellent and could hide the flash trim too. Sometimes the finish was a little hazy from the wax, but a quick buff and its super shiney… if i didnt use enough wax in the PE resin, sometimes there would be tacky areas remaining, so you need to do your own testing if you go this route. I figured it gave a more durable finish than a paint coating…
