So I dont know the name exactly but i am looking for suggestions on the best way to “V” the carbon from the center out. I have attached a pic of the part I am trying to make and the pattern as well.
Question 2
Since I am having so many issues with clear coats after molding, i was thinking of doing a either a 2k spray or Duratec Sun-shield application in the mold first. Is one better than then other for this type of work? I assume you would apply the mold wax and pva as you would normally be for spraying in the clear coat?
http://www.expresscomposites.com/?product=polyester-top-coats
