Am I wrong in this appproach ?: I made an aluminum intake for one of my turbo charged Z’s. My Idea/approach is to make a mold of it (clamshelled)…then make the two halves with CF,bond together with Epoxy and continue to wet layup further layers until a sufficient build is had. Clear coat with as high a heat clear as I can find.
The areas of the plenum which need a dense build for hardware would perhaps be blocks of CF that I’ve pressed/forged for machining and then bond to the tubes/runners. I have tossed the use of aluminum for expansion differences.The heat of an intake in a non-crossflow head can be extreme.
:?: You might think"whats wrong with just making them out of aluminum ?"
…Nothing ,other than that is also very time consuming and it heatsoaks.
I only plan on making about 10 of these total unless I can devise a less labor intensive way.
I’m asking: Does anyone on this board have experiance at this type of work ??
I’ll try and post a pix…Vince 8)
