Hi , just found this forum and theres looks to be alot of info on here and i was hoping that some one could help me with this .
I need to make a pipe 3 inches in diamiter with some 180 degree 3 inch radius ( to center) bends in it over a core i can disolve out later , i would like to make it in one peice and it is only for a air intake so will not have any load on it .
Is it possible for a carbon sleeve to go around a curve like this with out bunching up on the inside and what would be best to use as the core , idealy i would like a foam i can cast into shape but disolve out later .
Any info or advise would be appreciated , thanks .
