Hi there, I signed up to try to get some help in making a part that’s been giving me nightmares, I’ve worked with infused fiberglass for years so I thought I knew my stuff, apparently not. The part is a .875od carbon tube with a wall thickness of about .090, it’s part of a handlebar system for race bikes. I started trying to make the part by wrapping wet out 11oz carbon around a latex tube, then inflating it inside a clamped aluminum mold. That turned out promising, but had some voids between the tow, so I tried lighter cloth at the surface, same issue, then tried vaccum on the mold before inflating, led to a whole set of other issues, then tried infusing, building new molds that integrated a channel to seal butyl tape for 100% vacuum integrity, still had problems, like lack of resin between the tow and areas of the fiber that didn’t lay flat on the mold surface. then I tried prepreg, building a mold that had an integrated heater and controller to ramp, hold and ramp down temperature. this time the surface was perfect, but because I had to build the part in two halves with one half underlapping the other on inflation, the parts were too weak and split at the seam… seriously about to give up on the project alltogether…
posting pics of the prepreg mold and destroyed part. any help is appreciated
