I had high hopes for carbon nanotubes after reading that they offered a 20x increase in strength and stiffness over carbon fiber.
I thought that even if the claims were exaggerated by 50% or even 75% then their use would be a no-brainer. The problem is that I simply can’t replicate these results, or anything close, by adding nanotubes to my cf parts.
Out of all my experiments, the only one where I was able to make anything that was noticeably stronger or stiffer than a similar sized cf part was where I replaced the cf with nanotubes completely.
There was no scenario where using nanotubes as a resin additive (for a cf part) made a meaningful difference. Even when I added a whole gram of nanotubes tubes to 30cc of resin (which was around 50:50 by volume), the increase in stiffness was minor (no viagra jokes!) once it was spread across a woven fabric.
I am not done experimenting with nanotubes but all future experiments will be focused on using them as a casting product (mixed with epoxy). I could see some potential for creating fast injection molded parts that are stronger and lighter than equivalent cf parts. At $250 per kg, it will only be for high end products though.
Has anyone here had different results? I am thinking that I could be doing something wrong and perhaps there is a special method needed when using them to compliment cf parts? Or perhaps not all nanotubes are created equal?
