I wonât lie to you, that site uses the sledgehammer approach to composites. There are much better places to do your learning.
It looked like he started out making an overlayâŚand then popped the part out of the overlay, and instead built the overlay up as the actual replacement partâŚnot so good, since the sizing will be off! Also, the whole âvacuumâ bagging procedure shown there is pretty much a bust.
Go through the âArticles and Tutorialsâ section of this site, as youâll find all the information youâll ever need there, Werksberg has done a great job on this place!
Also, check out the âShowcaseâ forum, do some searches, and see if anyoneâs made anything similar to your projectâŚby seeing how theyâve done it, you can learn a lot yourself! Good luck, happy learning, and donât be afraid to ask questionsâŚjust be detailed when you ask them!
