carbon kevlar
Hi guys just started playing with glass and composites so may be a silly question when you wet lay a part using carbon kevlar when trimming the part what is the easiest of cleaning up the fluff from the kevlar
Andrew
Hi Andrew.
Depending on how big you part is , a little trick for the Kevlar fluff is use a bit of CA ( super glue and some kicker ( to set it fast) and it will sand off easy. I’m not sure how guys do it on big parts.
Tim
Thanks Tim i build small parts for model rc boats so ca may be just the trick cheers mate
