is the yellow kevlar one harder to work with… and is it thicker ?
for beginner…should i try to do overlay with regular CF instead ?
thx
thx
The Carbon/Kevlar will be tougher to work with, as the kevlar requires special cutters, whereas anything decently sharp can cut carbon reasonably well.
*edited to remove inaccuracies
ugh…the salesman said the twill weave is eaiser to work with around tight curves…ugh…
i’ll get some pure regular carbon tomorrow !
wow, deffinately the TWILL weave conforms better than a plain weave fabric
The issue with the kevlar is as FOZ says is cutting and final edge finishing
Ack, my bad! Got those two switched again…TWILL drapes around curves easier. :o
The kevlar doesnt wet out as nice either. I have to wet sand all my edges, then treat all the edges with resin, and then UV clear coat them.
Carbon Kevlar I use it in all my project. Specially in the last layer. Some times I make products only Carbon Kevlar and is very very strong.
