I wanted to show you guys some pictures from the carbon fuel tank I made for my Gsxr 750 k7. My first one was not great because off a reaction with my coating. So I had to sand it down to the carbon to fix it and it turned out well. It weights 1700 gram in total with tank cab and the original tank weights 4300 gram whitout tank cab. This is with a aluminium fitting at the bottom for the fuel pump. I thought that can be lighter as the tank is for myself so I made one off 1300 gram. I made them with infusion and applied a fuel resistant resin at the inside. The carbon fabric I used was a pain in the ass as it deformed with a slight touch.
