once again im having problems making a CF sheet lol, when the layup has fully cured there is very tiny bubbles in the face of the sheet ruining the part, my method is this -
sheet of glass waxed about 20 times with honeywax +
coat of poly resin surfboard resin so its nice and clear
4 plies of 200gsm CF rolled with paddle rollers like mad
finish coat of resin with wax in so i can rub down after
the sheet needs to be a good finish on both sides,
so, is there a better way of doing it to eliminate more or less ALL the bubbles ?
Vacuuming the sheet ? but i couldnt use peel ply as it will put the finish onto the sheet, but i could layup 3 plies of CF with peel ply then when that has set layup the last ply just as normal ?
how do you guys do it ?
seems like everything i do at the moment is going wrong and i just feel like giving up lol, if it wasnt for this excellent site i dont know who i would ask for help, so a big thank you to all of you
Matt
gets rid of pretty much all of the bubbles so im chuffed to bits
