This is the most recent of several I’ve built over the years. For those who are familiar with wheelchair specs, this one is for a 16"x16" cushion size; uses a single piece, angle adjustable 15" tall backrest assembly; a solid surface cushion base and footplate; 4" casters with suspension forks and 25" rear wheels. The headline number for a lightweight wheelchair is the “transfer weight” or the weight of everything except the rear wheels and cushion. This chair came in at just under 11lbs. The caster/fork assemblies are 1.5lb heavier than I normally use, but these do soften the ride quite a bit.
Ben
