Hello all - first post…! I very much respect this forum and the help so many people have given others. I hope to return the eduction in the near future.
I have a question. I need to create some carbon fiber tubes to support a top in a marine application. I have a foam core that I’m going to slide the carbon fiber sleeve onto. There will be a bend in the foam - so should I go a little tighter so it doesn’t bunch up?
The foam is 6 mm wide. Should I go with a 5.5 wide sleeve or should I go with 6? Or am I doing it all wrong…! I’m sure I’ll need to provide more info -!
