I write down a list of technical specifications for a type of 200gsm 3K 2x2 twill carbon fiber fabric:
Tensile Strength (MPa):4452
Tensile Modulus (GPa):235
Tensile Modulus (msi):34200
Tensile Modulus (kgf/mm2):24100
Elongation (%): .5
Mass per Unit Length tex (g/1000m):200
Fiber Density (g/cm2):1.786
Size Content by Mass (%):1.22
This is the specs i received from a supplier of carbon fabrics.
Because i have not ever reviewed in depth the mechanical characteristics of carbon fiber, could anyone tell me if thi type is any good? Could you give me the specs of another carbon fiber and compare them?
I need to step on the courses here so I can learn what EXACTLY strength and modulus, and stuff means
