Ok, I have been refining the process and materials used over the last year, I believe it’s close to going forward with full production but there are a few minor details that need to be addressed. Part; composite rifle stock using carbon fiber, kevlar, fiberglass, or carbon and fiberglass depending on weight requirements. Up to this point, all molds are laid up by hand using tooling gel coat and tooling resin, all polyester products primarily die to cost. The parts are laid up using epoxy resins, which is drastically reducing the cycle count of the polyester molds, so new more robust molds are top on the list.
The majority of the parts are laid up using a tinted epoxy base coat, so any micro bubbles or voids are not visible. When a clear carbon fiber part is laid up, a small amount of voids and air bubbles are present. I am sure they are in all the production parts, but only visible when the epoxy is left clear since there is no place to hide.
The layup method is as follows;
-a thin base clear or tinted epoxy brushed into the mold and allowed to tack. This eliminates print through and gives a much better surface finish
-layers of laminate placed in both sides of the mold (2 part closed mold), wet out by hand and rolled using bubble roller
-silicone bladder is inserted on one side of the mold, halves joined and bolted together
-mold is placed inside a vacuum bag, approximately 27 Hg vacuum is applied to the bag, bladder is then inflated starting at 10 psi ramping up to 40 psi, vacuum ran for 30 minutes. Bladder pressure remains at 40 psi for the cure cycle.
When the clear part is removed, there are areas which have trapped air voids or pin holes, which require repair thus increasing finish work. This brings me to the questions; do the final production molds need channels to allow the trapped air to evacuate? Current molds have about a 3 mil gap for flashing, which seems to allow the majority of trapped air and excess resin evacuate the part. Would increasing the bladder pressure potentially solve this?
Here is an image of the part
