Hi All,
I need to make a large number of carbon fiber sheets with a glossy finish on both sides.
Can someone please advise what technique i can use to get two side glossy finish through vacuum bagging maybe?
I have seen examples of stacks sandwiched with two glass panels but i dont think this is an efficient method plus i would like my sheet to be structurally strong with a high carbon/resin ratio though not required for this project.
Has anyone been able to use a mylar sheet on top of your stack giving you a glossy finish on both sides, if so how have you gone about vacuum bagging without any flow media.
The next part of my question is more important. Well the truth is i need precision sheets exactly 2.5mm in thickness as there are going to be engraved and cut through CNC so any difference in thickness is going to mess up my entire CNC code every sheet i try.
so the question is how does one achieve the thickness he wants every single time i do a wet lay up or vacuum bagging. I know there are precision sheets in the market.
How do these guys achieve the thickness every single time?
Hopefully someone can help.
cheers
