I am in the developing process of building a home built Tadpole (Reverse Trike) motorcycle with a target weight of around 550-650lbs and after much pondering i was thinking of trying out a hybrid design i came across on the FSAE forums, they built a frame out of 1/2" SAE1010 steel tube that was wrapped with 1 single layer of bidirectional 3k carbon fiber using carbon fiber sleeve material and their full build weight was 458lbs using an R6, 600cc motorcycle engine and having 4 wheels and supporting suspension. I am aiming for 550-650lbs as the max range using an R1, 1000cc motorcycle engine and only have 3 wheels, since there 1/2" setup with single carbon fiber layer was strong enough to last an entire race season, i am thinking of bumping up to 3/4" which is the normal tube size used on FSAE frames and wrapping it in an single layer of 3k carbon fiber sleeve material.
The questions i have is what is needed to protect the carbon fiber form the sun and elements? i ask this because i really like the look of the carbon fiber finished look and after thinking about it i was thinking i would find whatever finish coating i need and leave the carbon fiber as the “painted finish” instead of actually painting the frame. I built a Locost 7 previously out of 1" pipe that ended up weighing around 1200lbs that i had powdercoated black and the cheapest i could find within 100miles of me was $550 bucks, for as much pipe i would be using on this build i could single layer coat the pipe for less than half what i spent on powder coating previously.
My 2nd question is what kind of coating would need be between the carbon fiber and the steel pipe? Would the pipe be vulnerable to rust without painting the pipe layer first?
The way the FSAE group did it was they took all the pipe that they were going to build the frame out of and ran the carbon fiber sleeve across the length of the pipe, then they stuck it inside of a vacuum plastic material and vacuum’d it tell the resin cured, then when they built the frame the cut the already carbon fiber pipe to length and just handed back enough of the material to allow welding of the pipe together at the joints and such, then they used carbon fiber cloth to wrap over the areas that no longer had carbon fiber and the joints to strengthen them all.
