Hey Everyone, this is my first post out here, well im looking to make a really cosmetic carbon fiber sheet at 3mm thickness.
Done my research and it looks like theres no hard and fast rule to getting a cosmetic looking sheet on both sides of the panel, unless you use the rtm method or some other expensive manufacturing technique.
But with some brainstorming i wanted to check with a pro if this is reasonable to do.
What if i VARTM a sheet of 3mm thickness, demold it with my desired finish on only one side and then VARTM a single layer of carbon fabric simultaneously…
Now with two sheets of different thickness can i join them together perfectly to give both sides the cosmetic finish.
If i can do this please also let me know how would i go about joining these two sheets, epoxy adhesive or VAARTM again or wet layup sandwiched with clamps between two glasses?
