I say this could be a possible tip, because it might not work for you. One thing I really like to have is a clean, straight line when making seams on CF overlay. If you put the cloth in layers, it can sometimes lead to “bumps” that need to be filled with more resin and sanded. If you have ever seen a prepreg seam, it is perfectly clean with no fraying. I have had good success using the following for cutting clean lines in non-prepreg cloth. One note is that this only seem to work well using electric cutters like EZ cutters. Before cutting the cloth, I spray the underside with a coat of 77 and allow it to tack up. Then using the cutters I can cut a perfect line, no fray. The adhesive holds the fabric together. The cutters quickly, but gently cut the fabric without pulling at it. Then this piece goes directly on the overlay part.
What are other people doing to get good overlay seams?
