Does anyone know what kind or resins can be used to produce carbon fiber parts that will work with engine oil ?
One example of an epoxy resin that is designed for use in engine compartments is the Automotive Resin System from West System. This resin is engineered to withstand temperatures up to 400°F and is resistant to oils, fuels, and other automotive fluids.
It is important to use a resin that is specifically designed for use in engine compartments to ensure the durability and longevity of the carbon fiber parts.
