Hey first post here.
Been doing lots of reading and test trying to find a good way to infuse carbon fiber with surfboard resin.
I have a waxed piece of glass where i spray clear uv marine gel coat and let cure in a heated box till barely tacky.
Then lay one layer carbon and 2 layers of fiberglass cloth. Then peel-ply and then mesh.
My bag on this one could have been better and a slow leak and left the vac on longer than i would like cause the lay up to be a bit dry.
Had nice bubble free and pinhole free infusion though.
You can see if you look at the highlight the texture print through of the carbon or glass behind it.
Tried a second test with half gel coated and half not.
This time i wrapped the vacuum spiral hose side in the 3 layers of peel ply to act as a flow restriction to keep the part more resin rich this time.
Worked perfectly in that regard.
No Gel coat side i can physically see the carbon print through with almost bare fibers.
Gel coat side is better with no complete print through but i guess from the cure/shrinkage of the surfboard it prints through on the gel?
Sorry no picture here.
Not sure if my term usage is correct has far as print through is concerned please correct me if so.
I was looking at possibly changing to epoxy to see if i get better results.
Was hoping to stay with these products since it is a good bit cheaper.
I am looking at possibly using Duratec® Sunshield Clear Topcoat as my in mold gel coat with either surfboard or epoxy.
Id love to be able to get some gc50 as my in mold gel coat but i dont believe that is sold in the us yet?
This is the next attempt that turned out better.
http://imgur.com/dDmRoQC
For a bigger pic.
Here is the sample with starting from the left:
Gel surfboard sprayed on glass, then no resin, then gel coat sprayed on glass.
After curing the whole thing was infused with surfboard resin.
The surfboard sprayed section turned out perfectly flat with no bubbles.
The middle was surprisingly good with just barely visible fiber exposed since it had no resin sprayed on the glass.
Then the gel coat was the same good infusion but has print through, a bit hard to see in the pic i need to change my light angle.
But looks like i will be going with surfboard sprayed and then infusion with surfboard resin.
Going to pull an actual part this weekend so we shall see if it turns out good.
