Here’s a quick version. I will continue to work on a more detailed version:
Composites 101
This is the short version that goes straight to the step-by-step instruction. I will do a longer, more detailed write-up later on.
Materials, tools, and other requirements:
a. Carbon fiber fabric (duh)
b. Epoxy resin
c. Mixing cup
d. Cheap throw away bush
e. Disposable gloves
f. Blue masking tape
g. Sheet of plastic (saran wrap?)
h. Ample working room
i. Warm working area. Ideal room temperature is 70 degree Fahrenheit -
Preparation:
Caution, wear you gloves. This is going to get messy.
You will need to cut the fabric big enough to cover your plug (original piece) plus at least an inch extra on all sides. Use the blue masking tape to tape down along the cutting line and cut in the middle of the tape. This will help the weaves from separating.
Now comes the messy part. Mix your epoxy with the hardener accordingly. Most epoxy resin is mixed with a 3 to 1 resin to hardener ratio. You will also find some epoxy resin with different mixing ratio. Some are even measured by weight ratio and not by volume. It is important to measure the resin and hardener correctly or your part will not cure properly. Pour the resin first then add the hardener. Mix well for 3-5 minutes but not vigorously. Mixing too fast or too hard will cause a lot of air bubbles build up in your resin, which is always a bad thing. If you get too much bubbles after mixing, either let it sit still for another 5 minutes or so, or run a heat gun (a.k.a. hair dryer) over it to get the bubbles to rise and pop.
What’s pot life? That is the time you have to work with the resin before it starts to harden. Usually it’s around 15-30 minutes.
- The fun part:
Place your carbon fiber fabric on the plastic and wet both sides of the fabric with the resin using your brush of course. It is important to make sure that the resin gets soaked into the carbon fiber fabric thoroughly and evenly. Now wet the surface of the plug. Pick up the plastic sheet with the wet carbon fiber on it and place it over the plug. Press down and run your finger across the plastic sheet to press the fabric down on the surface. Use your finger to squeeze out any excess resin and air bubbles. Now lift the plastic sheet and let your carbon fiber start its curing process.
Notes: Curing can take anywhere from several hours to a week depending on the epoxy resin and the room temperature. Don’t place it in an area with too much moisture or under the sun. The fabric is cured when you place your finger over it and leaves no sticky fingerprint.
Q&A:
Question: My brush is hardened. Can I use paint thinner to wash it off?
Answer: Nope. That’s why you should use a cheap brush that you can afford to throw away after each use. I know, it adds up.
Question: Why is it taking so long to cure?
Answer: The cure time varies. You can try to speed up the curing time by putting it in a warm area. Running a room heater near it wouldn’t hurt.
Question: Ok, it’s done. But I can still feel the texture of the fabric. What do I do now?
Answer: If you want a flat and smooth surface to give you that 3D effect, you have to build up several more layers of epoxy resin. How many? It’s hard to say because different epoxy has different viscosity characteristic.
v.1.0. By Evan Nguyen for www.carbon-werks.com
Please direct any comments about this article to: info@carbon-werks.com
