At work, I’m the export focal, and deal with export classification quite often. Since your raw material isn’t used for a military part, the export jurisdiction falls under the US Department of Commerce. I’ll look up the ECCN and export restrictions for carbon fiber (although I suspect it will depend on the exact properties of the carbon fiber you’re dealing with).
If all you are exporting is raw material, look here: If you are exporting finished products, then the export classification will be different.
Start here:
http://www.bis.doc.gov/policiesandregulations/ear/index.htm
Raw materials are in category 1:
http://www.bis.doc.gov/policiesandregulations/ear/ccl1.pdf
Depending on your exact carbon material, check out these, in decreasing level of export control:
1C010 “Fibrous or filamentary materials” as follows (see List of Items Controlled).
Reason for Control: NS, NP, AT
1C210 “Fibrous or filamentary materials” or prepregs, other than those controlled by 1C010.a, .b or .e, as follows (see List of Items Controlled).
Reason for Control: NP, AT
1C990 Fibrous and filamentary materials, not controlled by 1C010 or 1C210, for use in “composite” structures and with a specific modulus of 3.18 x 106m or greater and a specific tensile strength of 7.62 x 104m or greater.
Reason for Control: AT
If your carbon material does not meet any of those categories, then your material is classified with an ECCN of EAR99.
For your information:
NS - National Security
NP - Nuclear Non-proliferation
AT - Anti-Terrorism
Based on commercially purchased carbon, for use in making wallet, I would guess that your carbon doesn’t meet any of those requirments in that document, and that it would be EAR99. If in fact it does not meet those requirements and it is EAR99, it will be a no license required (NLR) export. Even if you match the bottom category of 1C990, the only reason for control is AT, which means if you’re not exporting to one of the 5 terrorist supporting nations, then you don’t need an export license (NLR).
All of this information I listed is just for your information, to give you a very good starting point in export classification. DO NOT USE THIS INFORMATION AS FACT, please confirm yourself.
