I have a spare seat post for a bicycle that I am working on as my project involving carbon fiber. I’m doing this primarily to get some experience with carbon fiber. I plan on sanding down the area then reinforcing by wrapping it with carbon fiber fabric. I am unclear about a few things though:
How far down should I sand the area around the crack? If I don’t sand it down far and wrap it, there may be too much of a bulge in the repaired area.
It seems that I have a few options for what kind of fabric to use. I’m thinking maybe 2x ud (0,90deg) folded over the end of the post (the other side also has a small crack in it) then wrapping the entire post in the affected area with a twill fabric. The dunstone heat wrapping looks like it will work very nicely :-).
One concern that I have is that when the heat wrap compresses the seat post, the portion around the crack will cave in a little. Maybe I can use an expanding foam that I can dissolve with acetone. Is this necessary?
The wide selection of epoxy resins available also have me a little confused. Can someone recommend a strong epoxy resin system? I This will be my first time working with carbon fiber so I will most likely go with a hardener that gives me ~20min in the cup and around an hour when spread out. I read that the type of epoxy resin used has a significant impact on the final product’s strength. The final product needs to be strong enough so I can clamp it at or around the previously cracked area. Here is an image of how it is clamped on.
Here is a picture of the crack (it runs vertically). I can easily push one side down.
This can give you an idea of the material’s thickness. Notice the film the manufacturer forgot to remove!
