How would you guys design a cf gantry beam if ultimate rigidity (stiffness) and strength (in that order) was the goal?
This cf CNC gantry beam was designed by a CZ company using a filament winding process:
http://www.cz.compotech.com/content/images/MACHINE/IMG0404.jpg
I believe the tubes in the corners are steel. The tubes are drilled and tapped for the rail screws.
Obviously laying the cf weave in the correct direction will be key for any cf part design but in this case, I’m not convinced that the CZ company gantry design is optimal given that most of the force would hit at 90 degrees to the rails.
I think that the design would be better if the direction of the tubes was flipped 90 degrees and if they used a bunch of smaller tubes instead of just 4 long ones. I also think the rigidity would be improved if the structure was not hollow.
I am currently building my own cf gantry using a rectangle tube mold. Instead of making it hollow, I want to fill the void with a mix of carbon nanotube resin, chopped cf and a lot of cf tubes at 90 degrees to the linear rails. I have also sandwiched in some steel plates between layers of woven cf for the front face so it can hold the screws from the rails reliably.
How would you guys design a cf gantry beam for maximum stiffness and factoring in the need for it to be drilled and tapped for the rail screws?
I don’t have filament winding gear so I am using regular female molds with a mix of woven and random matrix fabrics. I have already made the front face (that will hold the rails). I am still playing around with the design for the rear half of the gantry.
Do you think it could be stiffer if I used a different shape? E.g. If the tube had a rounded back like a “D” shape tube. Or maybe a cf I beam like the ones sold by Dragonplate.
You can see where it failed, the rest of the part is in perfect condition.
