Hi, Kenkad. I’m new here, too.
About the bladder, I´ve just solved a similar problem by using casting silicone.
I´m not using air to get pressure. I´ve done mechanical force, which is deformating the silicone and so expanding it against the mould´s walls.
My part has one open side, and I´m doing pressure on that side.
But in a long bladder, you could do a cilyndrical hollow under rest and filling it with a slightly bigger cilynder in order to expand the bladder…
I used the part´s mould to make the bladder. Reduce the laminate´s thickness and cast the silicone (nice results with shore 13).
Thickness reduction can be accurately made by use of specific thickness wax sheets.
I´ve read a lot about avoiding direct contact between silicone and epoxy, but I haven´t had any problem with the silicone if completely cured. In any case, you could always isulate silicone by wrapping it or similar.
By the way, the silicone is a perfect reléase material and I don´t need to use any reléase agent at all (well, obviously you have to coat the mould later, for the epoxy…)
Hope it helps.
