I’m in the process of building a bonnet (hood). But I’m planning to use a 3 mm core material (soric) for this. I want to sandwich the soric between carbon (outside visible layer) and woven glass (inside layer). But instead of trimming the bonnet afterwards to the right size and shape, I’m planning to lift the correct size and shape bonnet out of the mold after infusion.
Reasons for this, I’m concerned that the white core material will be visible after trimming.
And with only garage hand tools I’m afraid i won’t be able to make a clean straight cut.
So I’m brainstorming with this idea. I heard about rolling edges, but i don’t understand the moulding process so here is my lay-up idea, will this work?
- Cut the first layer of carbon over size and bond it with infusion mold glue to the mold.
- Then cut the core material to the EXACT same size as the plug and glue that down
- Cut fiberglass to the exact same size as plug.
- Then fold over the excess carbon of step one over the other two, so theoretically speaking it should be the same size as the plug, lying from edge to edge in the mold.
Here is my (5 year old) drawing of my process,
is this how it should be done, or is there a hole in my plan…?
