hello,
I’m really sorry for making a mistake in data provided.
There are in fact two scenarios: One shown in these photos (in previous post) show core failure mode (cf) where it is nearly to be damaged, there strains and stresses (emax [maximum strain criterion]=0.09-0.14), tsai wu criterion (0.10-0.21), value =“1” means damage
all with weighting factor (safety factor) =2 (it is proper safety factor).
conclusion: there I can use double 6mm pvc core (because of low emax), -true /false?
The second secenario is : core failure in another place is 0.62 and emax =0.42 ,tsai wu =0.94 – this what you ve said general difference between emax and tsai depends on stiffness, like e = s/E, where e stands for epsilon and s for sigma.
Also checked (for that second scenario just for core, )
e1=-0.002 (core is compressed at that point) - I conclude glue to bending or even to buckling (when glue much stiffer than foam), true /false?
shear strain e12 (for core) approx =-00.2) - I conclude glue to be sheared when much stiffer then foam True /false?
e2 =approx. 0 - nothing bad can happen!
General opinion:
When glue will be:
-as much sticky as particles (microscale point of view ) of foam themselves
-as thin so no visible in cross section, or just like it
-having equal or less than core (itself) stifnesess E (Young modulus) an G (Kirchhoffmodulus)
When it would be just fine!
