I realize that post cure is required of many epoxy systems and is quite beneficial for ehancing the properties, but buying a real oven is out of the question.
What I have been thinking about is building an oven using the same principles as learned in grade 9 science class…or what ever grade that was. Where you made an enclosure that was lined with aluminum foil or something reflective and a clear top so that sunlight could come in and heat it all up.
I wonder if this could be used indoors with a similar setup but using a IR lamp to provide the heat and energy?
Would it allow for relatively uniform heating through out the box?
Any ideas?
