1: i doubt it. Styrene might clean it, but it’ll also clean everything it touches…like the skin off your bones. Nasty assed stuff. Acetone is the strong and SAFE solvent of the bunch.
2: When you are letting resin in, are you keeping the vacuum sucking? Because you can compact it down to 28, but what happens when you let the resin IN…the pressure goes up. That little amount might still let some trapped bubbles expand.
So, if you aren’t…keep the vacuum running the entire time until the resin gels.
Degassing the resin is always a good way to go as well. That is a standard practice. As with many threads, use a large bell jar, or metal case that can hold a strong vacuum. Let it in there for a few min, then let in the air.
