Hi all,
Recently, I made a part in carbon / kevlar by infusion, to replace an aluminum piece, but it is broken, I’m not sure why failed, I would like to know if it was my fault or part was too weak.
Some air came in during the infusion (I have no idea how it happened), but It didn’t seem too serious, this happened when the resin was gelled,vacuum was lost completly, (and then reapplied).
I ask because I plan to repeat the piece trying not to have any air in, but maybe it will break in any case… then would have to make a piece stronger.
Red, main fracture.
Blue delaminaccion.
Both pieces had the same dimensions except for the thickness, 8mm in the case of the aluminum part and 5mm carbon / Kevlar part.
Vf = 61%
this side is on compression
one layer of 100g/m2 plain charcoal
two layers of 823g/m2 triaxial coal
four layers of 600g/m2 twill carbon / kevlar
one layers of 823g/m2 triaxial coal
this side is on stress
What should I do?
Trying to do the same piece again, but this time with a perfect infusion, because a 5mm should be enough, or repeat adding more layers.
Regards and thank you very much
