breaking in a mould
hi ,
after polishing a mould how would you guys go about breaking a mould in using
  1. Paste wax
  2. semi - Permanant release agent?
thanks in advance:)
ben
Here is good article about seasoning a mold when using polyester based products: Why Molds Stick
Epoxy tooling can be a little different. Does your mold have an epoxy, VE, or PE based surface? Is the layup performed with epoxy, VE, or PE?
polyester. cheers
do people use PVA with semi permanents thou?
ben
I don’t use PVA with a semi. I use the semi sealer and the release You should test your system first though.
For breaking in a mould, a semi perm is not advisable. Also, the PVA will probably bead away from the semiperm.
For breaking in a polyester mould, just use paste wax and PVA. After a couple of pulls, you can revert to just paste wax or a semi-perm.
I never even noticed a break-in period with a semi-perm…at least with Frekote FMS sealer and 770-nc release. I use them straight off and have great success if the layup resin/mold surface/in mold coating is compatible.
If you start with wax and are going to convert to a semi-perm then you must completely remove the wax from the mold surface. Polishing compounds work well for doing this.
Using semi-permanent release to break in a VE/PE mould is fine. But prior to apply the sealer/release you should first give it a good post cure, Clean the mould surface twice with mould cleaner, then apply 3 coats sealer to a new mould, followed by several coats of release. After first release apply atleast one more coat of release.
