Try larger… 6 inch flange is better. Like someone else said in another thread, " if you don’t need 6" flange, just trim it down later." a 2" flange won’t allow you the needed room if you decide to infuse with the mold. The tape you can say takes up 1" of flange itself, then the spriral wrap, wrapped in peel ply takes up another 1.5 inches or so. You should take a look at Airtech’s resin flow strips that can be reused, resin won’t stick to them. They are long narrow channels that distrubute the infusion resin across a larger distance/area of the bonnet. Also since they are made of silicone rubber or something soft/flexible it won’t leave an impression in your finished bonnet. If you are infusing that is.
I use aluminum sheetmetal flashing that is thin and easy to work with. Tape it to the bonnet from the underside using aluminum foil tape. The tape i get from HomeDepot in the airduct isle, the flashing same store in the roofing isle. Any good hardware store should sell both. The flashing comes on a roll of 25ft.
Then use some modeling clay to fill in the tiny gap between the bonnet and the metal flange. Take your time with the clay work and get it as perfect as you can.
Best Wishes on your mold
