I found this online. I’ve used Hysol Loctite products a lot and can say they are VERY good. We used them to bond metal to metal and for gap filling then machining. yep some Hysol products can be precision machined even if needed. The price isn’t too painful on some of their products. I’m thinking about trying some Hysol#609 for bonding brackets to the backside of fiberglass/cf parts. It sets in 5 minutes and has a 3 minute work time. You can even buy the Hysol dispenser so it mixes the A&B as it comes out the mixing tip. As long as you clean and cap off the tip after each use it should last a long time.
http://www.loctite.com/int_henkel/loctite_my/binarydata/pdf/lt3355c_EpoxyUrethaneAdhes.pdf
Cure time and work time also.
