I have a mold that will be 2 parts, that will bond together to create a part with a hollow inner section. Since the mold is 2 parts, I’ll have flanged sections to trim off from both halves when finishing the part. If I create a solid glue line right up against the inner most part of the flanged area, would that create a sufficient bond line when bonding the 2 halves? The part thickness will only be around 2mm, so the butt joint is thin. If I can create a solid bead of glue, the bond line should be solid around the entire 2mm butt joint after trimming.
Would this work well? Or is there a better way to do this?
