I need to bond a one off part to an anodised (black) aluminium part for a bike frame Im making. (Its the rear dropout that holds the axle). Im not sure what type of anodising/sealing process was used as its an off the shelf part.
What would you do in this situation for surface preparation? My thinking would always be to abrade relatively vigorously with say 80 grit or something (no blasting facilities available) but this will almost certainly go through the anodising and surely that would defeat the point of anodising would it? Bear in mind this is standard anodising and not pre-bond anodising: Im not sure if theres a difference in the two
Have you found stronger bonds by fully going through the anodised surface or barely scuffing it or doing nothing at all?
The plan afterwards is to bond to film adhesive and glass carrier with epoxy.
