Hello Everyone,
I have made my epoxy wet lay-up moulds with Momentive Hexion F300 epoxy gelcoat and L326 tolling epoxy resin,I did hold the moulds while a day at room temp.And I put them into the oven onto plug firstly at 60 degrees for 8 hours then postcure at 80,100,120 degrees for 2 hour without plug.When I took them out,I saw blisters on the gelcoat surface.
Also gelcoat was not bond the epoxy resin.I have been applying 2 layers of gelcoat.I did wait 45 min between layers.And 4 hours later I started to wet lay-up.I have asked to Momentive Hexion but unfortunately nobody did back to me.I could not understand where I made mistake.Do you guys have any advice to me?
Thanks.
