Hi,
I’m interested in some DIY bladders if possible. prepreg 275 F cure. Aluminum molds. Love to be able to get a reasonable psi. (75-100)
What would be the pro’s and con’s for latex vs silicone?
Would silicone inhibit any secondary bonds with the finished parts? I was looking at some silicone over at smooth on.
I’ve looked at Piercan usa for the latex.
Any tips to making them yourself would be appreciated.
It’s essentially an air-tight canister that contains the correct volume of sand to fill the bladder. You can pressurize the bladder through this canister. While the bladder is pressurized through the canister you can tip it over and dump the sand into the bladder. My canister has a filter on one end so the sand can go back up the air feed line that goes to the compressor. It’s nice to also be able to apply vacuum through the canister. Once the bladder is full you can gently apply vacuum so the bladder stays the right shape. If you apply vacuum to quickly it will suck the sand back into the canister.
