good thinking
It’s definitely not a new technique. We just made a part here at my work using this technique, came out awesome. I also made a bridge for a student competition using this technique. The compaction is ridiculous… I had Boeing engineers asking how i made it and whether it was autocalaved.
This is one of my favorite techniques. It gives such good compaction. You do need a very strong mold to contain all the force of the silicone expanding. I know a good silicone that is easy to work with and has a hight CTE for this application if you need a recommendation. Also it’s good to imbed a piece of rope to help in removing the mandrel after curing.
I’m not sure exactly how to calculate the compaction in PSI, maybe some one else can give some equation for it?
You can also pour the silicone and use something to displace some of the volume if you want to control the compaction. What I mean is if you have a part with varying shape, the thicker bits will get more expansion and thus more compaction than the thinner bits.
Nice drawing by the way. Though I don’t thik you’ll need locators for the silicone mandrel. You could also cast the longer piece so it has a small recess for the longer T piece to fit in. The metal alignment stuff you show could pose more difficulty than a purely silicone piece. If you did want to use location pins, just cast the recesses into the silicone pieces, no need for sleeves or screws.
Of course this technique require making a mold for the silicone piece. You could either machine something, or 3d print the pieces, pour a mold, then cast the silicone pieces. You can also make the silicone with an an inner and outer piece, if necessary to help with it’s removal after curing.
You’re planning on doing a metal mold? You can do a two piece mold and then either layup right on the silicone, or you can lay up on the mold and then join them together. I’d just go right on the silicone. It’s pretty high durometer and would be easy to work with.
There’s a lot of considerations to make things fit, but very doable.
